HarishC
Issue with unassigning company card
Every time I unassign a company card, it automatically gets reassigned to the particular employee, it doesn't happen with any other employee in that card program.
Since that program is more of a CBCP we don't process those transactions thru concur and hence we unassign it manually. What could be the resolution for this?
@KevinD I'm expecting some insights from the Concur Community Champ.
JessicaL
Is there a field, like Employee ID, that matches in your card program site and the Concur site? If so, it could be automatically linking it. So, it would not matter if you unassign it because every time the file comes in, it would relink based on that information. For that, you could (hopefully) change that field on the credit card site - even putting 1 character in front of the matching field would stop it from relinking. Of course, Kevin is the expert πŸ™‚
Jessica
JessicaL
Jessica
KellyR
Also, just to let everyone know-- Kevin is taking a much deserved vacation at the moment! I'm sure he'll get back to you when he gets back. πŸ˜‰
Kelly Rigotti
Sr. Director, Digital Marketing
Munari_alEXPert
dear @bharp
The source of the issue you are having is from the setting of that credit card as mentioned also by @JessicaL .
Every credit cards is linked with an Employee ID in order to feed Concur.
Since you can not change the details from the credit card's source (as you are not working at the credit card company), if you are also the Company credit card administrator, contact your account manager or customer service of the credit card company in order to modify the Employee ID number of that card, or in case to have it blanked (if they can), so the card will be always stay unassigned.
Kind Regards
Alessandro Munari
HarishC
Thank you everyone on the solution and I'm confident that the solution would work πŸ™‚
@HarishC Just want to double-check on what the solution was to this issue? Did you change the employee ID as @JessicaL mentioned?
Thank you @Munari_alEXPert and @JessicaL for stepping in during my absence. πŸ™‚
Did this response answer your question? Be sure to select β€œAccept as Solution” so your fellow community members can be helped by it as well.
HarishC
Yes @KevinD , modifying the employee ID in the card source file seemed to do the trick.
Thanks again πŸ™‚
