- Mute
- Subscribe
- Bookmark
Is it Possible to Track Manual TAX/VAT Amounts Inputs?
Hi Experts,
We have a case where the VAT/TAX amount from a specific expense type, outputted in the reports/integration, is different from what it is supposed to be. Testing an expense creation as the user, we see the VAT/TAX amount field is editable and there is no rule for blocking it, so any input is accepted.
Before thinking about audit rules or any other ways to block it, I was wondering if we may capture these manual inputs in the Intelligence Reports, where it would be clear that a specific entry/line had a manual input.
Thanks in advance!
Felipe
- Labels:
Configuration
Help
- Mute
- Subscribe
- Bookmark
@felipeprevente off the top of my head, I don't believe this is possible. I don't recall every seeing or hearing about the system tracking whether a field was auto-populated or manually inputted.
- Mute
- Subscribe
- Bookmark
- Mute
- Subscribe
- Bookmark
Thanks for your reply. I was looking for a field/entry on the reporting side, but it seems we don't have such a thing.
Felipe
- Mute
- Subscribe
- Bookmark
Hi
did you get anywhere on your search?
- Mute
- Subscribe
- Bookmark
No, I didn't. Unfortunately.
- Mute
- Subscribe
- Bookmark
Hi @felipeprevente , cc: @SharronL
Just curious. I read you comment and get the impression that change of VAT/TAX amount field by the user is not expected/ to be blocked. Why not update the tax configuration to make the VAT/ TAX fields read-only or hidden to the user(s)?
http://www.concurtraining.com/customers/tech_pubs/Docs/_Current/SG_Exp/Exp_SG_VAT.pdf
Rohan Patil
✅Did this response answer your question? Be sure to select “Accept as Solution” so your fellow community members can be helped by it as well.
- Mute
- Subscribe
- Bookmark
Hi Rohan,
I do agree with you, and we have already made VAT read-only. But in this case, the goal was to capture expenses already processed with manual VAT inputs, where I wanted to know whether Intelligence has any field which tells us so.
Thanks for your response.
Felipe
