patilr1982
Implementation of CGST and SGST for India
With the introduction of GST by the Indian government, many multinational clients have adjusted their implementations to cater to this requirement. This post is to discuss the challenges faced and the solutions adopted.
Our first challenge was that there was no standard solution published by Concur when SAP came out with its own recommendations for the ERP. We have to admit that the introduction of the new government mandate was sudden.
The next challenge was the locations in India were not associated with the states. We went through a mapping exercise. One finding is that a couple of states like Uttaranchal were not defined. SO we had to set these up as well.
Next comes the modification of expense entry forms. We evaluated the VAT on expense types and decided to limit the new setup for only 5 expense types out of a total exceeding 30. This was to keep things simple for the users.
Next came the Tax authority set up. The Indian setup now resembles that for Canada. The complexity is driven by the number of registered entities you have in India.
You will have to set up a manual tax calculation and open up the Tax fields for user input. This is because the calculation of tax base amount is not straightforward and it is not easy to mimic the tax calculation specified on the receipts. So allow users to input based on receipts.
Final tweaks were required to handle tax on itemized entries. Calculate tax link is only available on parent entries and we had to switch off the copy down on new GST related fields as the itemized entries may have different rates of GST. We wanted to avoid accidental change at parent level from changing child entries. I know that there is a big popup. However, users are used to ignoring popups.
A question that remains is to determine how to manage change in tax rates. If 3 out of 4 rates change, will we end up with 7 values in the drop-down? If yes, how long do we maintain the old values?
Best Regards,
Rohan
12 REPLIES 12
patilr1982
The above post does not talk about changes to master data programs feeding data into Concur and posting program for posting documents in ERP system as these are essentially changes outside Concur system. Mentioning this as a comment because they are still within an organizations T&E ecosystem.
Best Regards,
Rohan
patilr1982
<duplicate post deleted>
Best Regards,
Rohan
vikesh
Hi Rohan,
Your post is very useful. Much appreciated.
Our organisation also has plan to setup GST configutation for India in Concur. Can you please guide me more on CGST/SGST setup. Do you have any document available for the same?
Thanks & Regards,
Vikesh
Justyna
Hello Vikesh, Our organization has some locations in India and I will be responsible for the Expense module implementation there. Could you please share with me best practices/ lessons learned for this particular configuration? Especially higly appreciated would be anything concerning taxes, because reading this discussion I can see it may be a challenge. Thank you Justyna
S0019810788
Hello Justyna
Could you please share with me, how you handle the intergration Tax CGST and SGST for India ? In my client there is an error posting from Concur to SAP
not able to post the multiple Tax for CGST and SGST from Concur XML data file to SAP.
Appreciate you can share the information to me, many thank you.
thanks and best regards
Weiheng
Marlene37
In my company we are also struggling to implement CGST/SGST with Concur & our SAP erp.
We are getting different error messages, could you please share with us how you finally set up your Concur for it ? Any documentations anything that could help us ?
Thank you
Marlene
S0019810788
Hello Justyna, could you please share with me, how you handle the intergration Tax CGST and SGST for India ? In my client there is an error posting from Concur to SAP, seem look like the CL_CTE Program not able to post the multiple Tax for CGST and SGST from Concur XML data file to SAP.Appreciate you can share the information to me, many thank you.  thank you and best regards Weiheng
Marlene37
Hi Vikesh,
Thank you
Marlene
victorwc
Hi @patilr1982
Thank you for sharing your insight!
My company is going to implement Concur T&E and Invoice to our Indian local subsidiary.
Could you kindly share your insight and experience on this subject?
I already found out one material regarding of this but it is only for promotion, not mentioning details of configuration.
https://www.concur.co.in/sites/default/files/in/unbox_gst.pdf
It would be appreciated if you can share your wisdom.
Thank you in advance!
Best Regards,
Wei
Crina
My company will implement Concur in our India subsidiary, too and I would like to see the details of the configuration. Unfortunately the link you shared is no longer available. Could you please share more details?
Thank you
Crina
Hello patilr1982,
My company will implement Concur in our India subsidiary, too and I would like to see the details of the configuration. Could you please share more details?
Thank you
Manoella_RT
Did anyone get a reply on this topic? My company is implementing Tax CGST and SGST for India and the concur consultant is not solving our issues. We have errors when the document is posted in SAP.
Can anyone help with materials or information on how to configure this?
Thanks in advance,
