I try to change XBLNR field content for Concur posting but getting error in interface. Would you have any advice how to get XBLNR changed. I use method IF_BADI_CTE_FIN_POST_ADJ_DOC~ADJUST_POSTING_DOCUMENT and
assign is_document_data-ADDITIONAL_DATA[ name = 'REPORT_ID' ]
to FIELD-SYMBOL(<fs_add_data2>).
if <fs_add_data2> is ASSIGNED.
<fs_acchd>-AWREF = <fs_add_data2>-VALUE.
And field AWREF
Br
Kirsi
@S0004200169 hello there. I'm showing that the company you work for is a Certified Concur Partner, is that correct? If so, you should submit your issue to the Partner Support Portal as we have dedicated Support people just for our Certified Partners.
