Jaewon
ICS Configuration Guide document
Where can I find and study the ICS Configuration Guide document?
A new project is starting soon, and I’d like to study it in advance.
It would be great if the materials cover both SAP ERP system and Concur-related configurations.
grodriguezproje
Hi @Jaewon
I found a post that maybe can help you
https://community.sap.com/t5/technology-blog-posts-by-members/a-step-by-step-guide-for-ics-integrati...
grodriguezproje
Hi @Jaewon
@Jaewon hello there. In looking at your community profile, I see that you work for a certified Concur partner. I need to let you that our Partner team has advised us that our Partners need to be using the Partner Support Portal for all questions/inquiries. We have a dedicated Support team just for our partners and that team should be your go to place for all questions.
We encourage you to share your expertise here on the Community with others, but for Support, please make use of our Partner Support Portal. If you have any questions, please let me know.
