lark1954
Expense with no receipt - tried to submit MRA and it doesn't give me the option to create a MRA
Hi there,
I'm relatively new to SAP expense reporting.
I've a parking charge used on my personal credit card where the receipt didn't print from the ticket machine.
I believe I have selected all the correct options when creating this receipt, including not adding an attachment/receipt to the expense, and selecting no receipt when saving the expense.
When I go to tick the box of the relevant expense > manage receipts > missing receipt affadavit, this screen comes up and doesn't allow me to create the MRA.
What am I doing wrong?
Thanks.
Can't select MRACan't select MRAExpenseExpense
Hi @lark1954 ,
Can you please check if you are getting receipt icon against parking expense type. Similar to the shown in below sample screenshot.
If yes, then select receipt status as receipt/tax receipt in expense entry and save. Now select the expense >> click on manage receipts >> you should be able to see parking expenses for the MRA.
If no, it means receipt is not required for that particular expenses. Hence, no need to attach MRA.
Note - MRA only works for those expenses where receipt is required (receipt icon should be visible) and when receipt status is selected as receipt/tax receipt but receipt is not attached.
lark1954
Hi Pooja and Kevin,
Thank you for your replies.
Upon checking, I do not have the receipt icon present. However, my company's policy always requires a receipt to be attached, otherwise you must provide a MRA (which I still cannot select). I'm still a bit confused as submitting this expense without  a receipt or MRA will not be accepted by my company, and be returned to me.
@lark1954 I was going to say the same thing as @PoojaKumatkar . I just looked at your report and this expense does not require a receipt. That is why the MRA is not available.
lark1954
I have just troubleshooted this with my manager and have managed to submit the report.
I wasn't aware that there was a dollar value where a receipt is not required, therefore there can be no creation of a MRA. Is it $20 and under, and is there a link to where we can find this info? It would be super super handy if perhaps a information box cropped up when trying to create a MRA for a missing receipt that totals less than whatever the stated amount is. Otherwise the box not giving you a reason to create it is a little unclear.
Thank you!
Hi @lark1954 ,
To show $ threshold limit condition for MRA just for user information purposes, adding a tool tip msg at expense type level or triggering warning msg on expense entry save is feasible , however, this is totally your company's decision whether to add it or not.
You can check this with your company Concur administrator.
Noufal_khan95
@KevinD ,
Can you check my company profile and see if my company has not activated the receipts status. We have issues where if card receipts/Card feed are available for any gasoline/Fuel - Employees are not able to attach MRA. Most fuel machines don't print receipts and we cannot advise on how to handle this issue. The amount is above $25 and receipt is mandatory for it.
Also, I have seen some employee's able to attach MRA even if there is card receipt/ card feed. Unable to understand what is wrong here. Maybe is this something with different policies / setting we have for different locations?
