Has anyone come across where the expense card icon isn't appearing for some transactions in the review stage? Usually no expense card icon would indicate that these are out of pocket expenses, however the payment type confirms it was charged to the employee's expense card. This was only for Uber transactions. The rest of the transactions had the icons correctly loaded.
Thank you
@marinapagnotta was this for one user or several users? Do you have any screenshots you can share? Also, if you private message me a name, I'll go in and take a look at their expenses.
Same for us, it is happening with many employees. And appears only airfare. Tested it doesn't appear under processor view, but when you emulate in and the employee it is on the ER.
We have had the same issue. It is happening with many employees. And appears only airfare. Tested it doesn't appear under processor view, but when you emulate in as the employee, it is on the ER.
LTenneson
Are e-receipts attached to these transactions, or standard uploaded receipts? I'm only noticing it so far for Uber transactions with e-receipts.
It appears with E receipts for us too
Same thing here. The e-receipt seems to be wiping out all other data (credit card/reservation). Very odd. If I don't see a solution here I will enter a support case.
We are having the same issue! Attaching example for admin. It's not triggered by report submit date or expense type so far in our troubleshooting.
