Trying to enter doctors for a CE event and I'm getting the following error message:
Cannot read properties of undefined (reading 'attendeeData')
Any suggestions?
We are able to retrieve a record searching both Veeva Open Data and a proprietary database, but for some records this error is returned when we try to save the searched attendee record to the expense entry.
Is there a solution?
@jasone do you have a screenshot by chance? I'm not familiar with that error. Also, are you doing a Doctor lookup or manually entering the doctor's information?
I've tried to enter doctor info, first and last name and also tried just by their NPI number. The doctor comes up but when I check the box next to their name and click "add" I get the error message. I've done hundreds of expense reports and have never had this problem. Attached is a screenshot. Thanks!
Also have a screen shot ... from a Veeva Open Data HCP search ... if needed. We have many problem tickets from this issue which began around last Thursday. The ticket submitters are searching two different databases ... Veeva Open Data and a proprietary database, with somewhat differently formatted data returned. In both situations, a record which has been returned via search cannot be posted to the expense entry .... same issue as described by Jasone,
@63378 looks like our Dev team is on the case. If you have Help tickets submitted, you should be kept up to date with what is happening in regards to the fix.
Is there an ETA on fix? This is an ongoing issue since Friday.
Ashish
Hi Kevin.
We appear to be having the same issue now ... two years later ... when a user searches an HCP database the records which match the criteria are returned, an appropriate record is selected, but the record does not post in Concur ... instead the user receives the following error: 'Cannot read properties of undefined (reading attendeeData)'. We have a large group of users who need this functionality = many help desk tickets. Our case # is 28504011 ... it is yet to be assigned to an analyst. We will appreciate any help you can provide to get this into the proper queue for a solution. Thank you!
We are also having the same problem with the MedPro Connector. Is there any resolution to this?
We are having the same issue as of this morning with our Salesforce connector. A user is trying to add a contact as an attendee and getting that error
We have escalated a ticket to Concur and understand their DEV team is aware of the issue and working on it.
Hi @jasone @athakur @anderste @pkinvesco
Please accept our apologies for any inconveniences caused.
The issue has been fixed. Let me know if everything works correct. Thank you!
Andras
Hello Andras,
We are still facing same issue. Just tested now.
I have a support ticket also open, but no update received about fix.
Ashish
thank you Andras! We are also still experiencing the error.
The fix was deployed 2 days ago for EU2, and it was promised to have it fixed yesterday by end of business day for US2.
Can you please check it now? Thank you
Andras
Thanks Andras, issue is resolved. Attendee functionality is now restored.
Ashish
Thank you Andras. We have tested and it appears to now be functioning as expected.
We are experiencing this problem AGAIN ... since Tuesday ... are others having this recurring issue as well?
Our users are experiencing the above issue with the IQVIA OneKey connector since Mon/Tues.
A ticket has been created with Concur Support and they are directing me to the App provider. Had to do my own research concerning the outage to direct Concur Support on how to address the issue.....Concur Support over the past few years has become very unsupportive. Where assistance with an issue typically isn't provided. You are either sent an "article" or steps to fix the issue yourself.
