brandtp09
Document for Typical Employee Import Errors
Is there a document in Concur that collates all the typical Employee Import Errors that can be found in the Error Logs for Employee Import?
Hi @brandtp09 ,
There is no such document available which can collates employee import error log.
Errors will only be found under employee import error log section. Those Error may vary based on your employee form or configuration design.
