dworth
Difference between Concur Standard versus Professional
In a discussion with consultants, I just heard there are two versions of Concur...  What are the differences/pros/cons of each?
Thanks!!
Darryl Worth
28 REPLIES 28
@SPGAB I'll send it to you here on the Community in a private message.
SarahM1
Hi Kevin, are you able to send a copy of this? We recently had a call with relationship managers but they have only offered calls with consultants rather than a brief overview which is what we asked for.
@SarahM1 here you go. This is for Concur Expense.
Andy_C
Hi @KevinD may I have a copy too please? Thanks!
@Andy_C see my response to @SarahM1 the document is in the reply. You should be able to click on the file.
SunnieZheng
@KevinD I would like a copy of the Feature Comparison document between Concur Standard and Professional.  We currently have Standard and are considering moving to Professional. Thank you!
@SunnieZheng if you scroll down this thread you will see my reply to SarahM1. The link to the document is in my reply. Also, you may notice that your email address is no longer in your post. We recommend not posting personal information in your posts. For future reference, as the site administrator, I do have access to the email address you added to your Community profile. 🙂
rizza03
Hi @proios  I believe you may find this content helpful. Feel free to add a comment in case you may need anything else.
