tstagliano
Copy Down Feature Not Working?
Has anyone else noticed that the Copy Down functionality is not working correctly or has been very inconsistent?  We have noticed over the last 2 weeks that there are some reports that are failing to be posted and when look at the details, the allocation level (eventhough we are not actually allocating a line item) is missing some of the Cost Object information that is copied down from the Report Header/Line Item and causing alot of extra work for our AP team.  Concur has noted that this is a bug but i am concerned that it is not happening to all reports so was just curious on anyone else having this issue.
The temp solution is to manually allocate all line items to the cost object type --> save the Allocation --> Then remove the allocation and confirm on the Detailed report that the allocation level detail shows the correct Cost Object information.
Thomas Stagliano, M.I.T.
0 REPLIES 0
