mageshkj
CONCUR SITE ISSUE
Hey Guys,
We are facing Concur site issue because of which our expense type name were got changes also see the screenshot below.
Instead of report name, report ID, and report key it is showing as Claim name claim ID and claim key.
rohanpatil
Hello @mageshkj
I would start by looking at the language selected in the profile settings. Some of the terms used and localisation will differ based on whether you use US English or UK English.
Hope this helps.
Rohan Patil
mageshkj
Thanks @rohanpatil we just go the response from the support that there was some Masking done which is causing this issue
Thanks @mageshkj . It is good to know. Claim was a term used in the past that I think is now retired. The masking you mentioned must have somehow reactivate the old terminology.
Glad it's fixed now.
Rohan Patil
