conissue
Bank Info Removal
I am getting the below error.
Please deactivate the banking details you have entered in your profile. You are in a group that does not require entry of your banking details in myExpense Concur.
I go into profile to update my bank details but it does not let me delete them. How can remove the bank details.
@conissue you cannot remove your banking information. However, on the banking information screen, there is a field labeled Active. Set this to No, then save.
