Twoodrum2025
Approver limits and global approval
Hi, I am new user with Concur. I am trying to locate where I can view what each approver limits are in what global. Thank you
@Twoodrum2025 you would see this if you have access to the Workflows option. This screen shows Authorized Approvers and their limits.
If you sign in to SAP Concur, click Home in the upper left. Under Administration select Expense. The Expense Admin screen opens. From here, look for Workflows. If you see the option, select it and see which tabs you can access. If you do not see an option for Workflows, then you don't have the correct permissions.
