CHill_FI
Amending expense parents when they are in use
Our Finance team have asked for us to amend the Parent list for our expenses as we have found there are 2 parents with the same number (only 1 used so far and now we want to use the other one). The current list has been set up and used for a few months now. Are we able to change this list? and are there are any issues with amending this after it has been used?
Current List
09. Development
09. Other
10. Finance use
11. Cash advance
12. Relocation
To-be list
09. Development
10. Finance use
11. Other
12. Relocation
13. Cash Advance
13. Relocation
@CHill_FI I'm back. My colleague confirmed that you can simply rename these parent expense types. It's just a name.
Once changed, I don't know if the Parent column on the Expense Types screen will update. You may need to navigate away from the screen and come back.
@CHill_FI I'm asking a colleague about this to make sure I get the correct answer.
Also, in your "To Be" list you have the number 13 twice and Relocation twice. I think maybe you didn't want it this way. 🙂
Would you consider keeping Cash Advance as 11. Cash Advance and make 09 Other be 13 Other? That way you are only changing one of the parents. Well, I guess you would be changing two items since you want Accounting Use Only changed to Finance Use.
CHill_FI
Thank you for all the help KevinD, this worked great - and thank you for spotting my fat finger mistake on the list 🙂
Cheers
C
