SAP Business Exchange
DimitriK
When using Affidavit the VAT setting should posted to Zero and Non-Recoverable.
Hi There,
Thanks & Rgds
Dimitri
Accepted Solutions
tstagliano
Re: When using Affidavit the VAT setting should posted to Zero and Non-Recoverable.
Dimitri,   You could also set the condition up within the Tax and Reclaim Groups setup to look at the Missing Receipt Affidavit field to see if the affidavit is set and if so, it will assign the zero tax rate that is unrecoverable
Thomas Stagliano, M.I.T.
micklavers
Dimitri, the Receipt Status will typically determine the VAT rules calculation.  When the Missing Receipt Affidavit is used the receipt Status should be "No Receipt" and the VAT calculated accordingly.   In some countries you can still claim the VAT/GST when using the Affidavit below a $ threshold.
You can add an Audit Rule to ensure the user can't use the Affidavit AND claim to have a Receipt or Tax Receipt.  Mick
tstagliano
DimitriK
Hi Thomas,
much appreciated.
Best regards
Dimitri
