SAP Business Exchange
BenH
Record Retention / Destruction Protocol in Compliance with Best Practices
Local record retention Best Practices calls for destruction of AP type records in 10 years.  What is Concur's default storage time for records to be available to me?  Does Concur have a mechanism through which I can control its retention / force destruction of our records that are held in Concur's system?
Ben
TrishW
Re: Record Retention / Destruction Protocol in Compliance with Best Practices
Hi there
There is a new functionality that can only be turned on by support called Data Retention.  it came out with May Service Pack.
Basically once they activate it, I believe Concur sstarts the count down (I think it may be 3 years.   However as a user, you can use the wizard to extend this.  Any changes made to the data retention only commences after 72 hours of the change (just in case of a disater?)
They sent me a document to read called Data Retention.  You may be able to find it on their documentation website or get your service admin to send you one
Hope this helps
Trish
BenH
Thank you Trish,  I will check this out.
Ben
