sreeleshskumar
Is there a platform change for Concur Reporting?
Hi All,
Is there a platform change for Concur Reporting? Currently it works on IBM Cognos. Is there any switch to Power BI or Tableu?
Thanks & regards
Sree
SusanT
Re: Is there a platform change for Concur Reporting?
I've heard there is a platform change, but only offered to SMB clients at this time. Would love to hear feedback from those on the new platform.
Cognos is still our reporting platform for our Professional and Enterprise clients. Our small to medium sized business clients are on a platform called Analytics that is an in-house reporting tool built directly into SAP Concur. If you are attending Fusion in March, be sure to attend my 60 minute presentation on Analytics so you can see what the tool looks like and how it functions.
SusanT
We are having significant trouble with Cognos and Windows 10 / Edge. I understand Cogos is not supported in Edge, but I really don't want to have to ask our users to go through Internet Explorer for Concur, just because of the Intelligence module.
I appreciate suggestions.  Thanks!
Susan,
A workaround you can have your employees try is to have your users log into SAP Concur through Edge and launch Cognos. Once Cognos opens, in the upper right-corner of the Edge browser window, you will see three dots. I've provided a screenshot. In the menu options that appear, they can select Open with Internet Explorer.
See if this will work for them.
SusanT
Thank you! I'll try this.
