Hi... I would love to connect Concur Travel and Tripit Pro, but the link in this green text is unresponsive:
It just does nothing. I have tried in Chrome, Safari and Edge.
For the context, I used to have these two connected when I was working for Microsoft. I moved over to GitHub, with a different environment.
I had to unlink my TripIt account from the Microsoft Concur environment.
I could never re-link it to the GitHub environment, because of this problem.
What can I do? Thanks!
@juanjocarmena here is how you can get help. Either email: support@tripit.com or use the feedback form here: https://help.tripit.com/hc/en-us/requests/new. The feedback form allows you to categorize your question, which helps the TripIt team answer your question more quickly.
