How do I change a report to a query and Vis versa? In a query how do I update the date to only be certain transaction dates. When I change the dates now, I still get all the old transactions and the new ones. It's like it only adjusts the end date not the beginning date even though I change that. Thanks for any help!
@mroberts_dmshg where is the report located that you are changing the dates but seeing old transactions?
I have found using Firefox for reporting is the best and allows for running reports similar to the older version.
