Diane
Report Studio
I have access to Report Studio, however when opening an existing report into the studio the "Page Explorer"/work area pane on the right-hand side is blank and not showing expected preview of report.
All other windows, selection items, etc are available.  Any ideas why I cannot see the report please?
@Diane I know Edge used to have an option to "Open with Internet Explorer", which is what I have advised others to try. I am trying to remember where the option is found, but I think near the upper right corner of the browser there are three dots that you can click to get some options. Give that a try. If not, I believe you could Google, Opening Edge browser with IE.
@Diane what browser are you using?
Diane
Hi @KevinD ,
Thank you for replying to my message 😊
I am using Microsoft Edge
Diane
Thanks so much Kevin!
I managed to find how to open Report Studio in IE browser and then had access to the preview pane.  I now also have sight of Query Studio which I didn't in Edge browser.
Thanks again, I will now click on the Accept as Solution.
