Auditinterne
Extract all card transactions from Cognos11
Hello everybody
I am trying to extract from Concur a list of all credit card transactions for all cardholders in my organisation over the prior 12 months. This is for internal audit purposes and I expect is a common request.
I have the Cognos11 BI module and have read through the catalog of reports but I can't find anything that addresses this request.
Can the community help? 🤞
@Auditinterne you can modify the standard reports, but it can be tricky because many of them contain Unions or Joins so you would need to know how to modify the different queries used in the report itself. There is a recording that shows how to modify a standard report that can give you an idea of how to do it. You can find the recording here: https://www.concurtraining.com/cnqr/cognos-11-registration
You may consider just building your own report. The list of items is quite long and there isn't a standard report that would include all those items, so building your report might be the best option.
cjmarimo
Hello @Auditinterne
We use that standard report: Analisys -> Finances -> Credit Card Transactions
My user has rol: Cognos Business Author
If you have the BI manager role, you will only be able to see the data of the employees assigned to you as a supervisor.
BR,
cj
@Auditinterne I think @cjmarimo gave you the best option. 🙂 Let us know if this report isn't working for you.
Auditinterne
Thank you @cjmarimo & @KevinD
I seem to have the correct BI profile to see the whole organisation’s data and was able to run that standard report.
It gives a base level of transactional data but I was hoping for a richer array of fields in the report. It seems to only provide:
Payment Type / Currency / Employee / Transacton Value / Merchant / Transaction Date / Posted Date/ Posted Amount.
Is it possible to modify the fields in this standard report?
We have recently migrated from another EMS and could extract the fields below:
EMPLOYEE ID / NAME / EMAIL
TRANSACTION REFERENCE
TRANSACTION LINE
POSTING DATE
TRANSACTION DATE
TRANSACTION TYPE
BILLING CURRENCY
AMOUNT
TAX AMOUNT
SUPPLIER INFORMATION
TRANSACTION STATUS
APPROVAL STATUS
SUPPLIER ID
SUPPLIER NAME
LINE AMOUNT
LINE TAX
SOURCE CURRENCY
SOURCE AMOUNT
Expense Description (Mandatory)
RECEIPT STATUS
GL Code
CC Code
Project
SUPPLIER CITY
SUPPLIER STATE
SUPPLIER COUNTRY CODE
SUPPLIER TAX REFERENCE
MERCHANT GROUP
MERCHANT CATEGORY
MERCHANT CATEGORY CODE
TAX CODE
WORKFLOW STATUS
LAST APPROVER
DATE
APPROVER COMMENT
ACCOUNT HOLDER COMMENT
Auditinterne
Thank you @KevinD It looks like I'm off to register for that training.
Auditinterne
For anyone looking for help on this in the future, I was able to get most of what I need by:
  • Requesting the Cognos Professional Author role
  • Building a custom report in Cognos 11 using Report Studio (accessible through the Home/Reporting/Intelligence drop-down in Concur.
The training here was helpful to start me off Building Custom Reports in Report Studio
As was the Data Model User Guide for expenses Analysis / Intelligence: Data Model - Expense Folder User Guide (concurtraining.com)
There is still some work to do to locate the table in which specific fields are saved – but I’m making good progress.
