mandarcoolkarni
Concur cognos report - 'my activities and schedules' unavailable on MS Edge ver.84
Hi Team,
I am using Concur cognos reports on Internet Explorer and can see everything fine with option as 'my activities and schedules'. But with same access, this option disappears on MS Edge browser ver.84.
As per the organisation requirement, MS Edge will be the primary browser for all SAP applications. Can you help if this something already fixed before?
Here is the snap -
@mandarcoolkarni unfortunately Edge will not support the My Activities and Schedules. There is a compatibility issue with Cognos and browsers that are not IE. This is something on IBM's end, not SAP Concur. I don't believe there has been a fix by IBM to correct this issue.
