AshleyB
SAP Concur, Former Employee
Concur Drive
Can anyone share their experience using Concur Drive? Things you like about it and don't like about it?
Ashley Bragg
ShaneB
When enabling the Mileage tracker, you are given the option (in regards to tracking your location) to select WHILE USING, but it says you must select ALWAYS in order to use the Mileage portion of the app. Besides this app Always tracking you even when you aren’t using it, it totally sucks your battery down. In order to get around this, you can go into settings under privacy and toggle the options there each time you want to use it. This is ridiculous. I can’t see how it got such a good rating. Two of the main things people are concerned about...Privacy and Battery.
My company requires us to use the Mileage tracker now for mileage reimbursement, otherwise I wouldn't use it!
