Barena
Joule Implementation Plan Needed
We are trying to put together an implementation plan to roll out Joule for Travel & Expense.  Is there a template,  guidance or best practice out there that can guide us to make sure we have everything covered?  Looking for detailed information including aligning requirements, engaging and assessing next steps, communication templates we might use,  etc.  Anything you can suggest and share would be appreciated.
@Barena have you asked your assigned Customer Success Manager about this. SAP Concur should have some setup guides for Joule. I just looked up your account and it says you are a Select Care customer. I would contact your Select Care Manager about this.
If you don't know who your Select Care Manager is, I can provide name for you.
