drakewinfrey
Issue with Concur Intelligence Link
We've been using Intelligence (Cognos) since 2019. Over the last month or so, the link no longer works for all our users. The page just buffers indefinitely.
Intelligence (Cognos 11) URL: https://us2.concursolutions.com/reportingmig/pod516/bi/
The interesting part, a user discovered that if you remove the 'bi/' at the end of the URL, and refresh, the page loads correctly.
Concur Support claims the issue must be on our end, so we are researching internally, but I'm curious if anyone else has experienced something similar.
ovidiu-ioanin
Hi Drake,
Can you try clearing your cache and access the link afterwards?
I get the indefinite loading pager or errors when cache adds up past a certain point.
Hope this helps!
drakewinfrey
Thanks for the reply! We've tried clearing the cache; unfortunately, that hasn't resolved the issue.
leedau
@drakewinfrey Thanks for posting in the SAP Concur Community. I would recommend opening a case in the SAP Concur Portal as an Authorized Support Contact to be investigated.
Lee-Anne Dautovic
