iknoxACU
Intelligence report check numbers
Is there a way to display the payment detail check numbers for paid invoices? I know on the invoice module only the processor and admin can view this detail. However, I was wondering if check number field can be access in an intelligence report?
@iknoxACU did you try using the Cognos search field to see if the data exists in the data warehouse? When you start a new report and are ready to start adding data items, at the top of the data warehouse there is a search field. Type in your key word or words, then enter. If the data item exists, the search results will show you were in the data warehouse it is. Give that a try. 🙂
