bcdowling
Home Screen - Expense on left menu
We noticed when we log in as someone else, they are seeing the Verify choice under their Expense left menu. Is there a way to get this hidden so it is not confusing to the employees who don't have access?
@bcdowling so I make sure I understand completely...when you go into someone else's profile you are seeing Verify as an option under Expense?
How are you accessing their profile? Are you using the Proxy option or are you using the Delegate option? I'm asking because these are different.
I'll await your reply, then go from there.
bcdowling
Yes, when I proxy in as another employee, I can see the verify on their expense menu.
@bcdowling and you have confirmed with these employees that they are seeing Verify when they are signed in to their profile? I would check that first because it is possible they aren't seeing it.
bcdowling
Ok, I will check this.
