- Mute
- Subscribe
- Bookmark
Cannot combine reservatrion and actual credit card charge.
Lately I have noticed that Concur is getting worse as matching up reservations with actual charges.
Ie: you make a reservation in Concur at a hotel and when the charge actually comes in after the stay, it used to do a better job of matching up the reservation (predicted cost) with the actual charge.
I have found that it has gotten worse at this lately. I have had to select the reservation and the and the charge and select the "Combine Expense" . I no longer can do this.
If I try to just expense the charge, it complains that there isn't a matching reservation. Which of course if false. It's there but the system doesn't realize it.
How do I combine the reservation and actual charge? I swear I did this in the past with the Combine Expense button.
