Asadsong
Iphone Error when logging in
Every time I want to login my Iphone App it gives me the information "Sorry, something went wrong.
We encountered an error processing your request. If the issue persists, please contact your Company Administrator or Help Desk with correlation_id 0239dce0-982f-40e6-9c41-c38d8be0e786-1 for additional help." But I can login on my desk top just fine, I have also deleted and reinstalled the app.
18 REPLIES 18
gcevallos
Yes, I am having the same issue.
Gabriela Cevallos.
@Asadsong and @gcevallos are you still having the issue?
Asadsong
@KevinD yes, I just tried to log in.
@Asadsong you might need your company's site administrator submit a help ticket on your behalf to SAP Concur Support.
Asadsong
I contacted her this morning.....
Ethan2023
@Asadsong  Hi, we also have this probelm. Did you resolve your problem?
leedau
@Ethan2023 you might need your company's site administrator submit a help ticket on your behalf to SAP Concur Support. Would you like me to send you a contact name for your company site administrator?
Lee-Anne Dautovic
Ethan2023
@leedau Hi, I am the administrator, and also submitted a case. But I have not received a feasible resolution until now.
leedau
@Ethan2023 Thanks for following up. I don't see an open case in the SAP Concur Support Portal. This is something the Support Team will be able to check for you. Do you have the case number? Feel free to send me a Private Message if you prefer.
Lee-Anne Dautovic
Ethan2023
Hi Leedau, I have resoved the problem with the help of technician from SAP.
jbergstrom
I keep getting the following error message on my new IPhone 14: The server encountered an error. If you continue to experience problems, please contact your company administrator. I have contacted them, and they do not know what to do.
Ethan2023
Hi, I have resovled the problem after submitting a case to SAP. Thanks!
mcnerney
 Hi @Ethan2023 Other than logging a Case, are you able to share what the solution/resolution was? Thanks!
Ethan2023
Yes, no problem. The resolution is as follows:
- Open the Settings of your iPhone (gear icon app)
- Tap Safari
- Disable the setting Block All Cookies, by tapping on it until it's grey
Ethan2023
No problem. The resolution is as the following:
- Tap Safari
mcnerney
Thank you so much @Ethan2023 !
Ethan2023
You're welcome.
mcnerney
In case it can help 1 person in the future, the user had that setting unset already, and had to unset
"Advanced Tracking and Fingerprinting Protection" in Advanced Safari settings (iPhone/iOS)
cc @Ethan2023
