Make Comments A Required Field For Miscellaneous
MitchellW
3 4 2,157
Make the comments field a required field for miscellaneous so employees provide more details on the expense.
4 Comments
DebbieNowak
would you do this in an audit rule?
JaninaBabaic
Routine Member - Level 3
We have done this a couple of our expense types, ensuring a comment is required.  It was done through forms and fields with the expense type.
KathyT
We require comment using an Audit Rule for Miscellaneous Expense Type because the Miscellaneous Expense Type the form used for it is also used on other expense types.
vskuda
We also have comment fields required on some expense types, managed through an audit rule. We just can't control what people choose to put in the field. Sometimes it's ridiculous.
