vibbertj
How do hotels increase their rankings for searches?
I am working with a hotel that is #6 on the list when I search for possible hotels near my work location. Is there a way to make one hotel rank higher? #1-5 are not as close and the prices are not always better.
Vishnu_Jayakuma
Hotels results in Concur Travel are displayed based on the Sorting set up in your company configuration. For Example - If the sorting is to show the Lowest Priced, then based on your search, Concur will first display the lowest priced hotel. However as a user you have the option to Sort the results, you can use this to place the results in an order and select the best option you need. sorting...jpg
