cthathana
how to reset mobile pin as i have problem with login into the app
Hi
please assist by sharing how to reset mobile pin as i have difficulty login into the app
@cthathana the mobile PIN has been done away with. You can sign into the mobile app using the username/login ID and password you use to log into SAP Concur on the web.
