Leez
Personal Car Mileage - Project/Order# Window
I'm attempting to submit a reimbursement expense report for travel using personal car mileage but the Project/Order# window is not giving me an option to enter anything. It says "Please answer Y or N" but anything entered is cleared as soon as I click out of the text box. I've refreshed and attempted at different times; still the same result.
@Leez from looking at your company's set up, the combination you selected for Company Code and Cost Center only allows N to be entered into that field. Those are what we call connected fields where what you select in Field 1 determines what can be selected in Field 2, etc. So, try typing the letter N in that field and see if it appears to select.
Leez
Thank you. That seems to be the case so I'll submit it as is and hope for the best.
