Hello! I was recently issued an Amex Corporate Card for business expenses. When I set up my SAP Concur account, there is an option to add an Amex Business Card for my Expense Credit Card, but I am unable to do so because I have a Corporate Card instead of a Business Card. How do I solve this problem so that my Amex charges start populating in Concur?
@TNTytell Here are the steps to register your card as well:
To register a card, the user must go to Profile > Profile Settings > Expense Credit Cards > Add AMEX Business Card
@TNTytell Hello! Thank you for reaching out to our Support team. Have you tried entering it in as a Personal Card? You could also reach out to your SAP Concur Admin to see how they would like you to add it. Let me know if you need your Admin's contact info!
Hi @MelanieT ! Thank you for getting back to me. When I was seeking out an explanation for my issue yesterday, I came across this:
Review the front of the credit to determine the card type:
My concern is that if I add my Amex Corporate card as a Personal Card, it will cause issues further down the road; if you believe that adding this as a Personal Card is the right move, then I will happily do so. I don't believe I have my Concur Admin's contact information, so if you'd be willing to share that, I would really appreciate it!
HI Melanie,
we have following error when we try to link AMEX corporate card with Concur. could you help out?
Hi @hzhuiedward ! I was able to work around this issue by adding my Amex corporate card as a personal card in Concur. I do need to manually adjust funding from Out Of Pocket to Company Paid, but all my charges are populating, so it's a workable solution for now. I hope this helps!
Hi TNTytell. we are in same situation, get tied of out of Pocket, I talked to Concur support and submitted case, they refused to fix it and said this is not priority items, very frustrated! !
@TNTytell I will send you your Admin's contact info. After further research you would need to add it as a Business Card, so you will want to have your Admin create a Support case so we can see why it will not allow you to add it.
