I always receive a message "Please inform the internal order". All the fields are correctly filled in. Could someone help me?
Thank you.
Laurent.
@Laurent I checked your SAP Concur account and it looks like the issue is been resolved, correct?
Thank you for your reply. I solved the problem on my smartphone. But on the PC application, it's still the same problem.
Thank you.
Laurent
