bwwhite
How to give expense approver ability to edit certain fields
Hello!
In our current set up, expense approvers can not edit any fields on expense reports that have been submitted by the users they manage.
Is there a way to grant edit permissions to expense approvers?
Thanks in advance for any help.
@bwwhite thank you for clarifying. In Standard, expense approvers can only change three fields; Business Purpose, Approved Amount and Comments.
Expense Processors can pretty much change all fields.
@bwwhite This depends on what configuration of SAP Concur you are on.
Do you know if you are on a Standard or Professional configuration?
Once I know this I can better answer your question.
bwwhite
Thanks for your response. We're on the Standard configuration.
Kevin_DFH
@KevinD what fields can expense approvers change in the Professional edition?
@Kevin_DFH pretty much all. There are a couple of exceptions, like Payment Type. It all depends on how the field is configured. Almost all fields can be set to Hidden, Read-only or Modify for Employees, Approvers and Processors. It just is a matter of what your company wants to allow.
edoss
Where can I find information on how to allow expense approvers to change fields in Professional platform?
