JCSE
HELP: How to claim fuel expense for work vehicle
I'm trying to claim a fuel expense using a scanned paper reciept detailing the date, time, location, amount of fuel and cost but concur gives me 2 errors.
"Applicable only in case of Car Rental."
"This itemized entry has sub-entries with one or more exceptions. "
How can I stop these errors and claim this fuel expense?
rohanpatil
Hello @JCSE
It appears that your company policy allows employees to claim fuel expenses only when renting a car. For personal cars, the fuel cost is typically included in the mileage rate configured. If you are using a company car, you are likely expected to use a fuel card.
I recommend reviewing the policy and training materials for further clarification. If these resources do not provide the clarity needed, please reach out to your internal support team.
If you are indeed using a rental car, ensure that the rental expense is included in the report. This should likely resolve the error when you save the entry again or resubmit the report.
Hope this helps.
Rohan Patil
@JCSE I agree with @rohanpatil I think you need to submit a mileage expense. I'm guessing this was for use of your own personal vehicle, correct?
JCSE
Thanks KevinD,
This expense was for a work owned vehicle, the fuel card did not pay successfully and I had to use my personal card.. I'll look into a mileage expense.
Cheers,
JCSE
crystalreports
At my org, if we use the personal mileage expense, that becomes a disadvantage to the Company because the mileage expense is supposed to cover all costs relating to using your own personal vehicle (depreciation, fuel, wear and tear, etc.)
Since this is a company vehicle and you merely want to get reimbursed for fuel you paid out of pocket, it seems it was such an unusual case that your company did not provide a way to handle it under the normal process.
Nancyagfa
We have a specific expense type if a fuel card for a company vehicle does not work.  The corp card can be used but the specific expense type needs a comment.  Have you tried another expense type with a comment?  We also have a misc expense that some could use for things that have no other place.
Nancy Murray
Agfa
