I have tried resetting my password and logging in and setting a pin but nothing works. I cannot get into the mobile app, but my password on my laptop works and I can access concur just fine.
Any thoughts?
Hi All,
Thanks for resourcing the SAP Concur Community for this issue.
We are no longer wiping phones directly from conversations happening here on the community. You will need to create a support case to get mobile errors resolved.
Here are two ways to get support:
For more general information on logging into your mobile app check out this video:
I hope this helps!
