Cannotl log into the SAP Concur App at a sudden. Error Message "Network Connection Error". What do I need to do to make it work again?
I get the same error - Trier it on different devices from Apple can‘t Login. Every Time the same Network Connection error
please fix it - Not Abel to Upload Ana expenses
I tried reinstalling the app, hard reset but I still get network connection error when opening the app. When is a fix expected?
Hey Team,
There were some issues I read with the connectivity, I also tried to submit my Expenses! Things should be almost back to normal now. If you do notice anything which isn't working as it should, have a chat with your company admin who can investigate and open a case with Concur if needed.
Hi Angus/all,
same error ‘network connection error’, can’t see to find any solutions or fixes on here - please advise if I have missed?
also how do we find ‘the champions’, there are no obvious support links, (apart from an online manual) on the Concur site!?
i hear lots of excited colleagues to get the app functionality but alas not able to enjoy due to the aforementioned issues.
thanks
what do we do?
Hi All,
With errors like these, the best solution is to contact your support channel. This could be the User Support Desk or your company's Authorized Support Contact. Your company will know which is the appropriate route. In both cases, they will be able to look into this for you and create a support ticket. This individual approach is necessary as no two instances of SAP Concur are alike and these issues would need to be address based on their unique configuration.
I hope this helps!
