larissawillett
Links to Concur Invoices
We are trying to figure out a way to generate a hyperlink in our ERP Software/Accounting system to quickly pull up a Concur Invoice.  Has anyone else tried this and have any advice whether it is something that can be done relatively easily?
Thank you!
dayfrench
Hi Larissa,
We do this! Every day, we receive PDF files for each invoice. They are saved on our network for our ERP to access. You will need to work with Concur to get the PDFs delieverd. But, it is possible.
Good Luck!
Dana French
Wintrust
