sarm_uk
Invoice Workflow by Cost Centre
Talking to a friend who is managing a Concur implementation for a UK listed company . Their concultants have advised hem the workflows can not be by cost centre where the cost flows determine the approves .
Last I worked on concur was 4 years ago , pretty sure you can achieve approval routing by cost centre by using connected list . Has anyone got nay experience in that .
SamuelD
You are correct can create workflow by CC - I have helped do it a few times!
