Bookkeeper
Mileage - distance entries
When an employee had a travel of less than one mile and Concur calculated from the addresses, it would not allow the entry and said the distance was invalid.  Are distances less than one mile not allowed within Concur expense?
@Bookkeeper the distance field works in whole number only. You cannot enter .5 or 1.25. One is the smallest amount that can be entered into the field.
jusouza
The distance field will not accent decimals and when you try to save a rounded up/down amount, the expense report will not allow you submit without and exact match on the distance field and google calculator.
jusouza
Oops. Meant that the distance field will not ACCEPT decimals
