JeffHaracz
"Help" widget
How do you disable the intrusive "help" widget?
It can be removed, but someone from Concur needs to do it for you, I believe. So, whomever you worked with in your implementation should be the person you can reach out to and ask.
Are you referring to the Question Mark in the blue circle? If so, if you mouse over it, a little X will appear you can click to close it.
JeffHaracz
That's the one but you have to close it every time you navigate to a different function.  Can it be permanently remocved?
