cdavila73
Personal Expense Code
Hello
 was submitting a personal expense, (MOVIE).  I didn't see a code to classify it under but MISC.  Can you advise if there's another code or if this is correct?
Thank you
AshleyB
SAP Concur, Former Employee
Thanks for posting! This might be a good question for your company's travel department. The answer will depend on your company's policy.
I am interested in also hearing from your fellow community members. Looking to learn how other companies handle personal expenses.
Ashley Bragg
As Ashley mentioned, it depends on your company. Companies have different expense types. Where you company has Misc, another company might use Incidentals or they might have an expense type specifically named Personal Expense. I would say in your situation Misc should work just fine. Also, the more important thing is that you marked it as personal. 🙂
