JohnFK
Concur - Setting up Approvers with $1 approval amount
Can someone point me to the directions for where I can change a 1st Tier  approver to $1?
@JohnFK
I can point you in the right direction, but can you first tell me what configuration platform you are on? Is it our Standard configuration or our Professional? If you aren't sure, an easy way to tell is go to the Administration option in the upper right-hand corner of the Concur home screen. When you mouse over it, do you see Expense Settings as an option or just Expense as the option?
Let me know which one you see and I'll be happy to help.
P.S. Why are you wanting to set a $1 limit for a tier 1 approver? Seems a bit low. 🙂
