Adriana
Attach multiple receipts to an expense line
What is the correct process to attach/detach multiple receipts at expense line?
Ex: I have a parking receipt and the credit card receipt which would need to be presented separately for internal check).
I saw that if I attach them at line level, system will display a pdf containing all attachments. Now, if I want to detach just one of the receipts, what would be my options? My system will completely remove the receipts and I need to attach again just the receipt I need.
Many thanks!
Adriana
If you use the Detach option it will remove all receipts assigned to that line item. You would then need to attach the correct receipt.
Adriana
is there any way to detach just one of the receipts? If I push detach, it will remove all receipts.
Many thanks!
Adriana
Orit_Dor
There are cases where we need to attach an email approval to an expense together with a receipt, that would be helpful to have more than one attachment in a line item.
Adriana
you have more items, oly they are attached in he same document. They are not attached individually.
kvilchis
How can we add the meal receipts to the Hotel, the folio is attached.  The system allowed one meal receipt to be "Combined" but will not allow the additional meal receipts.   These are required under our policy.     The old version permitted this but since switching to NextGen it is a problem.
