tstagliano
Consolidate 1 instance to another
Anyone go thru a process of consolidting an instance of Concur into a pre-existing instance?  If we were to purchase a company and they currently have an instance of Concur that we would want to merge into our existing instance of Concur, is there a specfici process to go through?
Thomas Stagliano, M.I.T.
You cannot merge two different instances of Concur. I'll give one reason...So, you have Company A acquring Company B. Company A's domain for logging in is something like: username@companyA.com. When you try to merge all the users from Company B into Company A's site, then it would think these are new users. Since their domain (login) doesn't match Company A, you would get an error or it would see these new users in Company A's sites, but since their login is still on record from Company B, you would get an error that the usernames for all of Company B's employees are already in use.
I hope that makes sense. I'm sure there are a lot of other reasons, but this one is probably one of the easiest to explain.
tstagliano
i understand the log in issue which is easily resolved giving the users of Company B with new logins to company A.  I am more concered about data and configurations from Company B and how they can be incorporated into Company's A already configured and operational org
They would have to be manually configured in the new site. There is not copy to feature. So, any audit rules, custom workflow, etc. would have to be manually done.
frankvo
hi Kevin
would it be possible to merge two instances if the domain is the same?  meaning in this way a manager that needs to approve members over 2 instances only needs to login once.
thanks
frank.
@frankvo you cannot have one log in that gives access to two instances. The users must have a profile created in the same instance as the approver.
Although you can have two companies that use the same domain, the user will only be able to log in to the instance where their profile resides.
I wanted to provide a little clarification here on this subject.
While merging or combining the configurations of two sites into one site is not possible, you can merge users from one instance to another. Also, here are some resources that might prove helpful regarding this scenario.
Mergers and Acquisitions: A Practical Guide
Checklist: Due Diligence for Mergers and Acquisitions
Mergers, Acquisitions, and Your SAP Concur Solution: Best Practices for T&E Leaders
